Ir para o conteúdo principal
Pebble Time Steel - reparing of a non working button
O que você precisa
  1. Pebble Time Steel - reparing of a non working button, Repairing of a non working button: passo 1, imagem 1 %32 Pebble Time Steel - reparing of a non working button, Repairing of a non working button: passo 1, imagem 2 %32
    • With opening picks we start to open the watch by lifting up the display bottom from left (about seven o'clock) in counterclockwise direction. In the left side there is a flexband that has to be disconnected.
  2. Pebble Time Steel - reparing of a non working button: passo 2, imagem 1 %32
    • Three screws are removed.
  3. Pebble Time Steel - reparing of a non working button: passo 3, imagem 1 %32
    • down on the left, a Flexband is carefully folded up and loosened. Below it, another screw is visible.
    • Remove this screw.
  4. Pebble Time Steel - reparing of a non working button: passo 4, imagem 1 %32 Pebble Time Steel - reparing of a non working button: passo 4, imagem 2 %32
    • Then the board can be removed carefully.
    • If you look closely at the keys, you can see that the defective key no longer carries rubber dabs.
    • With a needle, the smallest drops of superglue are dripped into place of the missing rubber.
    • Now put everything together in reverse order. Remove the sealant before applying the display and stick it around with a new Tesa 61395 Tape 1mm.
    • Then insert the display and press down.
Conclusão
Repeat the steps in reverse order to reassemble your device.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Vasco Dunker
Membro desde: 12/02/18
256 Reputação
Autoria de 1 guia
2 comentários
thanks , I managed to fix my pebble time steel with this guide. it may not be waterproof but at least my buttons no longer stick…
I think the reason it failed was because some water already got inside… could get my pebble starting anymore
Kah Kin Yau - Responder
Works great! Thanks for the guide :D
I would've liked to add an additional step, but it doesn't appear that I can - one other thing that I've found can cause buttons to stick is in the inside of the casing, on each button there's a little circlip that sits in a detent on the pokey bit - if this comes out of its detent, then the button can become quite hard to press and hard to work with. Unfortunately I can't post pictures here, but there's a picture in this Imgur thread of what I'm talking about: https://imgur.com/gallery/V4SUvbz
Aadi Bhamidipati - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 1,655
