Ir para o conteúdo principal
Pebble Time Round Glass Screen Protector Replacement
O que você precisa
  1. Pebble Time Round Glass Screen Protector Replacement, Glass Screen Protector: passo 1, imagem 1 %32
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Glass Screen Protector Replacement: passo 2, imagem 1 %32
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
Conclusão
Kyle
Membro desde: 11/01/21
85 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 Membro de UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 328
