Ir para o conteúdo principal
Pebble Steel Vibration Motor Replacement
O que você precisa
  1. Pebble Steel Vibration Motor Replacement, Internal Hardware: passo 1, imagem 1 %32 Pebble Steel Vibration Motor Replacement, Internal Hardware: passo 1, imagem 2 %32 Pebble Steel Vibration Motor Replacement, Internal Hardware: passo 1, imagem 3 %32
    • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
    • Make sure the screws are kept in a safe place to insure they are not lost.
    • Remove the back plate.
  2. Pebble Steel Vibration Motor Replacement: passo 2, imagem 1 %32 Pebble Steel Vibration Motor Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
    • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
    • Adhesive on the back side of the battery holds the internal components to the front case.
    • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
  3. Pebble Steel Vibration Motor Replacement, Vibration Motor: passo 3, imagem 1 %32
    • Use a small plastic opening tool to remove the vibration motor from the motherboard.
  4. Pebble Steel Vibration Motor Replacement: passo 4, imagem 1 %32
    Comprar
    • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Orlandria Heggs
Membro desde: 10/01/15
527 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-7, Leahy Fall 2015 Membro de USF Tampa, Team 1-7, Leahy Fall 2015
USFT-LEAHY-F15S1G7
Membros da 3
Autoria de 5 guias
2 comentários
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - Responder
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 3,106
