Introdução
I go step by step through how to replace an input jack on the Peavy XM4 Amp/Mixer
O que você precisa
All of the dials have a rubber cover and a nut, these need to be removed from all of the dials. The Jack inputs also have a nut holding them in place, remove these also.
Remove the input jack by desoldering the pins on the other side of the board, you may want to use a solder remover tool to make it easier.
Solder the new jack in place, the jack i used had an extra pin but was not needed. i ended up bending it out of the way and it all still works.
Once the jack or jacks have been replaced simply re-assemble by working backwards, remember that the dials each have a screw and a topper. when putting the toppers back on make sure the dials are turned to the minimum value and line them up to avoid confusion when being used.
Uma outra pessoa concluiu este guia.
