Introdução
A short repair guide to fix a broken toy car from Paw Patrol manufactured by Spin Master. The fault is, that the actuator button only works on defined positions of the fork. It is the garbage truck of the dog Rocky.
O que você precisa
This is the truck we are talking about. The Spin Master garbage truck of the dog Rocky from the TV series Paw Patrol
You can now remove the bottom half from the top.
Inside the truck you will find two LEDs for the lights.
A speaker for the sound.
A small PCB.
Also there are the connections from your battery holder
You can remove the orange fork to get a better view of the contacts.
I had to reflow them with the soldering iron and bent them a little bit down to avoid further touching of the fork shaft
Go the steps revers to reassemble the toy.
