Introdução
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
- Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
- When applying the rubber cement to the hole, the thinner the layer the better, for faster drying.
O que você precisa
Press the valve core while applying pressure to the tire to deflate the tire.
To reassemble your wheel, follow these instructions in reverse order starting at step three.
6 outras pessoas executaram este guia.
