Introdução
Holes in a down jacket can mean being a walking pillow-fight. Prevent feathers from leaking and ensure that the hole doesn't grow with a temporary patch. While patching your jacket with repair tape will hold for a while, and is a great way to repair on the fly, eventually you will want to put a real patch on the jacket. For details on patching a down jacket, check out our Baffle Repair Guide.
For replacement parts or further assistance, contact Patagonia Customer Service.
O que você precisa
Inspect the damage. Clip any dangling threads, fabric, or feathers using small scissors. .
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Use a spudger, hard plastic card or the edge of your thumb to smooth out patch and work out any air bubbles underneath. Continue to smooth out patch by applying downward pressure onto patch, pushing out towards the edges in all directions.
Using your warm hand continue to apply pressure until properly adhered.
Allow patch to set for at least 24hrs before next wash.
25 outras pessoas executaram este guia.
10 comentários
I have now put four or five tenacious tape patches on my son's down sweater (9 year old are tough in VT). But now it is very dirty. Can I wash it like I would if it didn't have the tenacious tape - or do i need to do something different?
Hi Hylah, Yes you can wash your jacket and if the patches are starting to peel a little after 7 years you have some options. 1) Contact Patagonia Burlington Store and ask for some more patches, each store has a variety of patches, zipper sliders, Zipper pulls, snaps, buttons to help with easy repairs. 2) Send it to us for Repair, you could take it to the store or start the process on-line . https://www.patagonia.com/returns.html
Holes are not warranty but due to wear and tear, we will repair it for you no problem. Our goal is to keep product in use as long as possible. After they have reached there end of life use, we can recycle it for you and then you can invest in another long lasting durable product. Please check out this link for additional questions. https://help.patagonia.com/s/article/Rep...
Hi Sheilaym 1, Everything we make can be washed, Cold water Low tumble dry. It's good to wash your shells every once in a while to remove dirt and oils.
I've found super glue works pretty well and doesn't show the down.
