Introdução
In this guide, you will learn how to repair your own vehicle tire from punctures like nails or holes. Repairing your own tire is a great way to save cost on replacing the tire for a new one. The machines used can be very dangerous and should be used with great caution.
O que você precisa
Look around the tire to see if there is any nail, cracks, or holes.
Once the leak is found, mark it.
Once the leak is identified, evacuate the air from the tire using the valve stem removal tool
Lay the wheel on the tire machine and use the tire iron to pull out the upper bead.
Use the tire machine to spin the wheel counter-clockwise.
Once the upper bead is lifted off the wheel, remove the lower bead
Once the tire is removed from the wheel, removed the nail from the tire using the dikes
Place the tire on a secure and well lit area to prepare for a patch by grinding the inside of the tire
Use the die grinder to grind around the puncture to leave enough room for a patch to stick
The surface area of the grinded area must be level and larger than the patch
Apply an even layer of vulcanizing cement glue over the area that was grinded
After the glue is dry, gently lay the patch at the center of the puncture.
The patch must be smaller than area that was grinded
Use the stitch roller to roll the patch in a crisscross pattern onto the tire for a permanent seal
Put the tire back onto the tire machine.
Start by installing the lower bead
After the lower bead is on the wheel
Use the tire iron to install the upper bead
Use the air hose to inflate the tire to the correct psi
Insert the small tire valve stem you saved from earlier
Now that your repair is finished, it safe to say that you have given the tire a second chance by extending its life. You saved money by reusing this tire, additionally lowering the amount of rubber waste that is demolishing our environment.
