Ir para o conteúdo principal
Parrot Hydrofoil Orak Propellers Replacement
  1. Parrot Hydrofoil Orak Propellers Replacement, Propellers: passo 1, imagem 1 %32 Parrot Hydrofoil Orak Propellers Replacement, Propellers: passo 1, imagem 2 %32 Parrot Hydrofoil Orak Propellers Replacement, Propellers: passo 1, imagem 3 %32
    • Locate the propellers of the same angle, each diagonally across from each other.
    • Locate the propellers of the opposite angle, located diagonally across from each other.
    • Grip each white propeller firmly and pull up to remove.
    • Removing the propellers may require a decent use of force.
    • When replacing the propellers make sure to place the corresponding set in the right position, diagonally across from each other to ensure proper liftoff.
Conclusão
Jacob Munson
Membro desde: 10/06/16
200 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 20-2, Livingston Fall 2016 Membro de Cal Poly, Team 20-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 759
