Ir para o conteúdo principal
Parrot FLYPAD Joystick Replacement
O que você precisa
  1. Parrot FLYPAD Joystick Replacement, Joystick: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Total of 6 Screws are located in the back of the controller.
    • Four 0.9mm T6 screws
    • Two 0.1mm T6 screws
    • Flip the Flypad over.
    • Remove the six screws using a T6 screwdriver.
    • Use a Magnetic Mat to prevent loss of screws. Set aside.
  2. Parrot FLYPAD Joystick Replacement: passo 2, imagem 1 %32
    • Flip the Flypad over again and separate the front and back. Be sure to remove the foam adhesive that connects the front plate to the motherboard.
    • Be aware that the Buttons (L1,R1) may fall out. Remember to put them back in place during reassembly.
    • Use Ph0 tool to remove the screws holding the motherboard in place.
    • Gently remove the motherboard from the front plate.
  3. Parrot FLYPAD Joystick Replacement: passo 3, imagem 1 %32 Parrot FLYPAD Joystick Replacement: passo 3, imagem 2 %32
    • Pop the joysticks out by pulling gently.
  4. Parrot FLYPAD Joystick Replacement: passo 4, imagem 1 %32
    • Unscrew and replace joystick caps for a more comfortable grip.
Conclusão
HUY NGUYEN
Membro desde: 04/10/17
376 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S3-G5, Liner Spring 2017 Membro de UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
Membros da 5
Autoria de 3 guias
2 comentários
Do you know where I can find replacement joystick caps like the one shown in Step 4, please?
cbeilstein - Responder
Same question as above regarding joystick caps please
Alex - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 684
