Ir para o conteúdo principal
Parrot FLYPAD Buttons Replacement
O que você precisa
  1. Parrot FLYPAD Buttons Replacement, Buttons: passo 1, imagem 1 %32 Parrot FLYPAD Buttons Replacement, Buttons: passo 1, imagem 2 %32
    • Position the controller so the back is facing up.
    • Use a T6 screwdriver to remove the six screws on the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Buttons Replacement: passo 2, imagem 1 %32 Parrot FLYPAD Buttons Replacement: passo 2, imagem 2 %32
    • Remove the foam adhesive that connects the front plate to the motherboard
    • The buttons (L1,R1) may fall out. Set aside to replace during reassembly.
    • Use a Phillips #0 screwdriver to remove the two 0.7 mm screws.
    • Remove the motherboard from the front plate.
  3. Parrot FLYPAD Buttons Replacement: passo 3, imagem 1 %32 Parrot FLYPAD Buttons Replacement: passo 3, imagem 2 %32 Parrot FLYPAD Buttons Replacement: passo 3, imagem 3 %32
    • Remove the buttons from the front plate of the fly pad and replace as needed.
    • Hold the front plate of the fly pad facing downwards to prevent buttons from falling out.
    • Make sure the text on buttons L1 and R1 correctly line up with L2 and R2 when reassembling the device.
Conclusão
HUY NGUYEN
Membro desde: 04/10/17
376 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S3-G5, Liner Spring 2017 Membro de UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 575
