Ir para o conteúdo principal
Parrot Bebop Drone Styrofoam Nose Replacement
O que você precisa
  1. Parrot Bebop Drone Styrofoam Nose Replacement, Battery: passo 1, imagem 1 %32 Parrot Bebop Drone Styrofoam Nose Replacement, Battery: passo 1, imagem 2 %32
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone Styrofoam Nose Replacement: passo 2, imagem 1 %32 Parrot Bebop Drone Styrofoam Nose Replacement: passo 2, imagem 2 %32
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone Styrofoam Nose Replacement: passo 3, imagem 1 %32 Parrot Bebop Drone Styrofoam Nose Replacement: passo 3, imagem 2 %32 Parrot Bebop Drone Styrofoam Nose Replacement: passo 3, imagem 3 %32
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone Styrofoam Nose Replacement, Styrofoam Nose: passo 4, imagem 1 %32 Parrot Bebop Drone Styrofoam Nose Replacement, Styrofoam Nose: passo 4, imagem 2 %32
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone Styrofoam Nose Replacement: passo 5, imagem 1 %32
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone Styrofoam Nose Replacement: passo 6, imagem 1 %32
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
Conclusão
To reassemble your device, follow these intructions in reverse order
Equipe
UW Tacoma, Team 1-3, Rose Winter 2017 Membro de UW Tacoma, Team 1-3, Rose Winter 2017
UWT-ROSE-W17S1G3
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 937
