Ir para o conteúdo principal
Parrot Bebop Drone GPS Board Replacement
O que você precisa
  1. Parrot Bebop Drone GPS Board Replacement, Battery: passo 1, imagem 1 %32 Parrot Bebop Drone GPS Board Replacement, Battery: passo 1, imagem 2 %32
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone GPS Board Replacement: passo 2, imagem 1 %32 Parrot Bebop Drone GPS Board Replacement: passo 2, imagem 2 %32
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone GPS Board Replacement: passo 3, imagem 1 %32 Parrot Bebop Drone GPS Board Replacement: passo 3, imagem 2 %32 Parrot Bebop Drone GPS Board Replacement: passo 3, imagem 3 %32
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone GPS Board Replacement, Styrofoam Nose: passo 4, imagem 1 %32 Parrot Bebop Drone GPS Board Replacement, Styrofoam Nose: passo 4, imagem 2 %32
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone GPS Board Replacement: passo 5, imagem 1 %32
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone GPS Board Replacement: passo 6, imagem 1 %32
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
  7. Parrot Bebop Drone GPS Board Replacement, GPS Board: passo 7, imagem 1 %32
    • Remove the cable from the top of the GPS module.
  8. Parrot Bebop Drone GPS Board Replacement: passo 8, imagem 1 %32 Parrot Bebop Drone GPS Board Replacement: passo 8, imagem 2 %32
    • Remove the two 6mm T5 torx screws holding the GPS module. There is one screw on each side.
    • Remove the 4mm T5 Screw holding the GPS Module.
  9. Parrot Bebop Drone GPS Board Replacement: passo 9, imagem 1 %32
    • Remove the GPS board by lifting it off of the metal frame.
Conclusão
4 outras pessoas executaram este guia.
Austin
Membro desde: 02/02/17
185 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-3, Rose Winter 2017 Membro de UW Tacoma, Team 1-3, Rose Winter 2017
UWT-ROSE-W17S1G3
Membros da 4
Autoria de 5 guias
Um comentário
With voice driving directions maps <a href="https://play.google.com/store/apps/detai...
">GPS Voice Nevigation with speed</a> limits with speaking ,user can get accurate gps coordinates for car GPS navigation.In gps driving guide 2019 users can listen to voice input for voice navigation which gives out all of the audio instructions for direction gps towards destination point on the maps
Albert - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 2,656
