Ir para o conteúdo principal
Parrot AR.Drone 2.0 Motor Replacement
O que você precisa
Vídeo de Apresentação
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: passo 1, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: passo 1, imagem 2 %32
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: passo 2, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement: passo 2, imagem 2 %32
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Motor Replacement: passo 3, imagem 1 %32
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: passo 4, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement: passo 4, imagem 2 %32 Parrot AR.Drone 2.0 Motor Replacement: passo 4, imagem 3 %32
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: passo 5, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement, Motor: passo 5, imagem 2 %32
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: passo 6, imagem 1 %32
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: passo 7, imagem 1 %32
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: passo 8, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement: passo 8, imagem 2 %32
    • Carefully wiggle out the motor assembly out of the arm.
Conclusão
5 outras pessoas executaram este guia.
David Hoyt
Membro desde: 04/09/10
4.023 Reputação
Autoria de 43 guias
Equipe
Cal Poly, Team 25-89, Amido Spring 2010 Membro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
Membros da 4
Autoria de 63 guias
2 comentários
are the motors different on each side?
dbksoft - Responder
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 5,755
