Ir para o conteúdo principal
Pantech CDM8975 Screen Replacement
O que você precisa
  1. Pantech CDM8975 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Open the flip phone so that the screen and keyboard are facing you.
  2. Pantech CDM8975 Screen Replacement: passo 2, imagem 1 %32
    • Remove the four screws at the corners of the screen.
  3. Pantech CDM8975 Screen Replacement: passo 3, imagem 1 %32 Pantech CDM8975 Screen Replacement: passo 3, imagem 2 %32
    • Use a spudger to separate the back shield from the top half of the phone.
    • Warning: Remove the battery prior to removing the screen.
  4. Pantech CDM8975 Screen Replacement: passo 4, imagem 1 %32
    • Set the phone down with the exposed side facing up.
  5. Pantech CDM8975 Screen Replacement: passo 5, imagem 1 %32
    • Near the hinge of the phone there is a green circuit board.
    • On the underside of the board, there is an orange plastic connector that connects the battery to the screen.
    • The LCD screen is the metal square with the black LCD screen in the middle (this should not be confused with the clear plastic protective screen on the front of the phone).
    • Pull the LCD screen out with your fingers and disconnect the circuit board from the orange plastic connector with the spudger.
  6. Pantech CDM8975 Screen Replacement: passo 6, imagem 1 %32
    • The original LCD screen will have components (like a microphone, speakers, etc.) attached by wires. If your replacement LCD screen is similar, then take out the original LCD screen (with attachments) and replace it with the new LCD screen. You can skip steps 8-11, since they do not apply to this situation.
    • Note: If your replacement LCD screen did not come with components (like microphone, speakers, etc.) attached, then continue with the guide as written.
    • Using wire cutters, disconnect the speaker from the phone.
    • Your phone will look different from these pictures, since the cutting steps have not been performed. Follow the steps in the guide for true instructions - pictures are only to help illustrate locations of steps.
  7. Pantech CDM8975 Screen Replacement: passo 7, imagem 1 %32
    • Pull the wires from the screen which connect to the speaker carefully.
  8. Pantech CDM8975 Screen Replacement: passo 8, imagem 1 %32 Pantech CDM8975 Screen Replacement: passo 8, imagem 2 %32
    • Carefully remove the screen. Leave the wires from the speakers exposed (top of the phone).
  9. Pantech CDM8975 Screen Replacement: passo 9, imagem 1 %32 Pantech CDM8975 Screen Replacement: passo 9, imagem 2 %32
    • Make sure all of the wires are out of the way before inserting new screen.
  10. Pantech CDM8975 Screen Replacement: passo 10, imagem 1 %32
    • Put the new screen into the phone.
    • Solder wires into screen if necessary.
  11. Pantech CDM8975 Screen Replacement: passo 11, imagem 1 %32
    • Reattach the backing of the phone with the four screws.
    • Your phone should now be operational (after reinserting the battery). If it is not, revisit the steps, and make sure everything was reassembled correctly.
    • If your phone turns on and displays, you are finished!
Linha de Chegada
Chris
Membro desde: 02/13/14
1 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-4, Meza Spring 2014 Membro de Ohio State, Team 1-4, Meza Spring 2014
OSU-MEZA-S14S1G4
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 552
