Ir para o conteúdo principal
Pantech Burst Motherboard Replacement
O que você precisa
  1. Pantech Burst Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Pantech Burst Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Pantech Burst Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Power off your phone before beginning disassembly.
    • Turn over the phone so that you're facing the back cover.
    • Locate the indent(?) below the back cover.
    • Using a fingernail, pull up to remove the back cover.
    • Removing the back cover may require some force.
  2. Pantech Burst Motherboard Replacement: passo 2, imagem 1 %32 Pantech Burst Motherboard Replacement: passo 2, imagem 2 %32 Pantech Burst Motherboard Replacement: passo 2, imagem 3 %32
    • Locate the silver battery. It is the big, rectangular, silver tape on black plastic object.
    • Find the gap between the battery and the rest of the device.
    • Using your fingernail, gently pull the battery up and away from the rest of the device.
  3. Pantech Burst Motherboard Replacement: passo 3, imagem 1 %32 Pantech Burst Motherboard Replacement: passo 3, imagem 2 %32 Pantech Burst Motherboard Replacement: passo 3, imagem 3 %32
    • Undo all 8 visible screws using a phillips size 000 screwdriver.
    • The screws are marked in red on the picture.
  4. Pantech Burst Motherboard Replacement: passo 4, imagem 1 %32 Pantech Burst Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the SD card if there is one inserted into the phone.
  5. Pantech Burst Motherboard Replacement: passo 5, imagem 1 %32 Pantech Burst Motherboard Replacement: passo 5, imagem 2 %32 Pantech Burst Motherboard Replacement: passo 5, imagem 3 %32
    • Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port.
    • Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged.
    • Once there is space enough to pull the pieces apart with your fingers, you may do so.
    • Opening the phone may require a good amount of force.
  6. Pantech Burst Motherboard Replacement: passo 6, imagem 1 %32 Pantech Burst Motherboard Replacement: passo 6, imagem 2 %32 Pantech Burst Motherboard Replacement: passo 6, imagem 3 %32
    • Unscrew the screw with a phillips size 000 screwdriver.
    • Disconnect the blue connector from the motherboard using a fingernail to lightly pull up.
    • Gently remove the SIM/SD card part.
  7. Pantech Burst Motherboard Replacement: passo 7, imagem 1 %32
    • Gently disconnect the connectors attached to the motherboard using a fingernail to pull them up from the board.
    • Connectors are marked in blue in the image.
  8. Pantech Burst Motherboard Replacement: passo 8, imagem 1 %32 Pantech Burst Motherboard Replacement: passo 8, imagem 2 %32 Pantech Burst Motherboard Replacement: passo 8, imagem 3 %32
    • Starting from the bottom and going around counterclockwise, carefully pry the motherboard out of the device.
    • Beginning with the side with the USB port may damage the phone.
Conclusão
Kyle Kurashima
Membro desde: 09/29/15
111 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-1, Green Fall 2015 Membro de Cal Poly, Team 15-1, Green Fall 2015
CPSU-GREEN-F15S15G1
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 460
