Ir para o conteúdo principal
Pantech Breakout Battery Replacement
O que você precisa
  1. Pantech Breakout Battery Replacement, Removing Back Cover: passo 1, imagem 1 %32 Pantech Breakout Battery Replacement, Removing Back Cover: passo 1, imagem 2 %32 Pantech Breakout Battery Replacement, Removing Back Cover: passo 1, imagem 3 %32
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
  2. Pantech Breakout Battery Replacement, Removing the Battery: passo 2, imagem 1 %32 Pantech Breakout Battery Replacement, Removing the Battery: passo 2, imagem 2 %32
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Murphy
Membro desde: 09/25/14
898 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 5-5, Mcgee Fall 2014 Membro de USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 1,912
