Ir para o conteúdo principal
Pandigital Super Nova Front Facing Camera Replacement
O que você precisa
  1. Pandigital Super Nova Front Facing Camera Replacement, Battery: passo 1, imagem 1 %32
    • Remove the screw covers from each corner of the back side of the device.
    • Set aside.
  2. Pandigital Super Nova Front Facing Camera Replacement: passo 2, imagem 1 %32 Pandigital Super Nova Front Facing Camera Replacement: passo 2, imagem 2 %32
    • Using a Philips screwdriver, remove all four .15 mm screws from each corner.
    • Set aside.
  3. Pandigital Super Nova Front Facing Camera Replacement: passo 3, imagem 1 %32
    • Using the plastic opening tool, remove the back cover of the device.
  4. Pandigital Super Nova Front Facing Camera Replacement: passo 4, imagem 1 %32
    • Remove the three .11 mm screws that hold the battery in place.
    • Set aside.
  5. Pandigital Super Nova Front Facing Camera Replacement: passo 5, imagem 1 %32 Pandigital Super Nova Front Facing Camera Replacement: passo 5, imagem 2 %32
    • Unplug the battery and remove from device.
    • Avoid touching the motherboard as it is fragile.
  6. Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: passo 6, imagem 1 %32 Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: passo 6, imagem 2 %32
    • Use a metal pry tool to separate the camera and the small clip that holds it in place.
    • Do NOT touch the MotherBoard with your bare hands. There is risk of short circuiting the device. Use nitrile gloves to prevent this.
  7. Pandigital Super Nova Front Facing Camera Replacement: passo 7, imagem 1 %32 Pandigital Super Nova Front Facing Camera Replacement: passo 7, imagem 2 %32
    • Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
Conclusão
sterling hannsz
Membro desde: 10/10/16
267 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team 1-2, Bennett Fall 2016 Membro de Texas Tech, Team 1-2, Bennett Fall 2016
TTU-BENNETT-F16S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 108
