Ir para o conteúdo principal
Pandigital Novel PRD07T10WWH7 Wireless Card Replacement
O que você precisa
  1. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement, Wireless Card: passo 1, imagem 1 %32
    • Remove the back panel by sliding it downwards and pushing in slightly.
  2. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 2, imagem 1 %32 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 2, imagem 2 %32
    • Pry off the second white panel, removing two clips underneath.
    • Start from the middle, and then work on the sides. The sides may be difficult to remove, so try to focus on one side and work your way around.
  3. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 3, imagem 1 %32
    • Using a Phillips #0 bit, remove the 12 4mm screws.
  4. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 4, imagem 1 %32 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 4, imagem 2 %32 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 4, imagem 3 %32
    • Pry off the gray piece by removing the clips around it.
    • Then, unplug the battery and separate the gray piece from the motherboard
  5. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 5, imagem 1 %32 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 5, imagem 2 %32
    • Using a Phillips #0 bit, remove the two 3mm screws at the top of the wireless card.
  6. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 6, imagem 1 %32 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: passo 6, imagem 2 %32
    • Unplug the wire from the wireless card.
    • Flip up the retaining flap, releasing the card.
Conclusão
Samuel Carey
Membro desde: 10/19/16
401 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 175
