Introdução
Dropped your camera, or forgot to put the lens cover back on then your lens is damaged. Any scratches or chips in a lens will alter your most valuable moments and leave you with an imperfect image. This guide will show you how to restore the quality of camera you deserve.
O que você precisa
Remove one 5mm screw on the bottom side of the camera with a Phillips #0 screwdriver.
Quase terminado!
Conclusão
