Ir para o conteúdo principal
Panasonic VDR-D220 DVD Camera Front lens Element Replacement
O que você precisa
  1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: passo 1, imagem 1 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: passo 1, imagem 2 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: passo 1, imagem 3 %32
    • Remove one 5mm screw on the bottom side of the camera with a Phillips #0 screwdriver.
  2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 2, imagem 1 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 2, imagem 2 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 2, imagem 3 %32
    • Open the side port door.
  3. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 3, imagem 1 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 3, imagem 2 %32
    • Remove one 5mm screw inside the side port with your Phillips #0 screwdriver.
  4. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 4, imagem 1 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 4, imagem 2 %32
    • Using a plastic spudger, pry to disconnect the top-front part of the camera.
    • Slide the top portion of the camera forward revealing a ribbon cable.
  5. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 5, imagem 1 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 5, imagem 2 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 5, imagem 3 %32
    • Flip the camera on the right side.
    • Gently pull the front part from the main body to reveal the cables connecting them.
    • Do not pull too hard because of the ZIF connector cable.
    • Use your plastic opening tool to disconnect the connection point safely.
    • Press the tab with a plastic opening tool and then pull the ZIF connector to detach.
  6. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 6, imagem 1 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 6, imagem 2 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 6, imagem 3 %32
    • Look at the camera from the front side.
    • Remove four 5mm screws using a Phillips #0 screwdriver.
    • There are two 5mm screws on each side of the lens, for a total of four screws.
  7. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 7, imagem 1 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 7, imagem 2 %32 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 7, imagem 3 %32
    • Pull the front element lens gently away from the camera.
    • In some cases the lens need not be replaced completely. Sometimes cleaning the lens with a microfiber cloth and isopropyl alcohol will alleviate blurry video issues.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 174
