Ir para o conteúdo principal
Panasonic Toughbook CF-53 Optical Drive Replacement
O que você precisa
  1. Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32 Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: passo 1, imagem 2 %32
    • Orient the laptop onto its top and face the bottom towards you.
    • Remove the 3 mm Phillips #00 screws securing the Wi-Fi card/optical drive plastic cover.
  2. Panasonic Toughbook CF-53 Optical Drive Replacement: passo 2, imagem 1 %32
    • Remove the 5 mm Phillips #00 screw on the silver tab to the left.
  3. Panasonic Toughbook CF-53 Optical Drive Replacement: passo 3, imagem 1 %32
    • Reach under the silver tab and push the optical drive out of the side of the device using a spudger.
  4. Panasonic Toughbook CF-53 Optical Drive Replacement: passo 4, imagem 1 %32
    • Now that the drive is completely disconnected from the device, slide the optical drive out of its slot.
    • The end of the drive may seem to be stuck inside the device during removal. If this is the case gently wiggle the drive side to side and apply a small force until it pops free.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,614
