Ir para o conteúdo principal
Panasonic Toughbook CF-53 Battery Replacement
  1. Panasonic Toughbook CF-53 Battery Replacement, Battery: passo 1, imagem 1 %32 Panasonic Toughbook CF-53 Battery Replacement, Battery: passo 1, imagem 2 %32 Panasonic Toughbook CF-53 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Orient the laptop on its side so that the plastic battery cover is facing upward.
    • Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
  2. Panasonic Toughbook CF-53 Battery Replacement: passo 2, imagem 1 %32 Panasonic Toughbook CF-53 Battery Replacement: passo 2, imagem 2 %32
    • Use the battery release slider to release the battery latch.
  3. Panasonic Toughbook CF-53 Battery Replacement: passo 3, imagem 1 %32 Panasonic Toughbook CF-53 Battery Replacement: passo 3, imagem 2 %32 Panasonic Toughbook CF-53 Battery Replacement: passo 3, imagem 3 %32
    • Use the blue tab to pull the battery out of the battery compartment. Make sure to keep the battery latch tab depressed while doing so.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
Rick Reeves - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 91
Duração total: 6,005
