Ir para o conteúdo principal
Panasonic Toughbook CF-29 Wireless Card Replacement
O que você precisa
  1. Panasonic Toughbook CF-29 Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 2, imagem 1 %32 Panasonic Toughbook CF-29 Wireless Card Replacement: passo 2, imagem 2 %32
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Wireless Card Replacement, Back Cover: passo 3, imagem 1 %32
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 4, imagem 1 %32
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 5, imagem 1 %32
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 6, imagem 1 %32 Panasonic Toughbook CF-29 Wireless Card Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 7, imagem 1 %32
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 8, imagem 1 %32
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Wireless Card Replacement, Wireless Card: passo 9, imagem 1 %32
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  10. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 10, imagem 1 %32
    • Peel back the black cover to expose the clips holding in the wireless card.
  11. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 11, imagem 1 %32
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  12. Panasonic Toughbook CF-29 Wireless Card Replacement: passo 12, imagem 1 %32 Panasonic Toughbook CF-29 Wireless Card Replacement: passo 12, imagem 2 %32
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
Conclusão
Devon Augustus
Membro desde: 04/12/10
130 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 27-93, Amido Spring 2010 Membro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
Membros da 4
Autoria de 26 guias
Um comentário
what about the heatsinks of the processors? You don't fix the contact surface to the cover?
michael - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 23
Duração total: 14,694
