Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the bay door for the battery on the left side of the laptop.
Slide the latch to the right and then down to unlock it.
Pull out the battery.
Locate the door for the hard drive on the right side of the laptop
Push and slide the latch up to open the hard drive door.
Pull out the hard drive.
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Push the exposed switch to the left to eject the optical drive.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Now the back cover should be off and you can access the inside of the casing.
Locate the track pad chip near the handle.
Remove the upper right screw.
Use a pry bar to detach the white ribbon cable shown.
Push the brown tab to release the cable
Remove the screw that was previously concealed under the now removed ribbon cable.
Remove the rightmost ribbon cable
Pry up the brown clip
Tug the cable out
Remove the last ribbon cable.
Pry up on the brown part to release the ribbon cable.
Uma outra pessoa concluiu este guia.
