Introdução
This guide will show you how to gain access to and replace the track pad board in your Panasonic CF-29.
O que você precisa
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Locate the track pad chip near the handle.
Remove the upper right screw.
Uma outra pessoa concluiu este guia.
