Ir para o conteúdo principal
Panasonic Toughbook CF-29 Optical Drive Replacement
  1. Panasonic Toughbook CF-29 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Optical Drive Replacement: passo 2, imagem 1 %32 Panasonic Toughbook CF-29 Optical Drive Replacement: passo 2, imagem 2 %32
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Optical Drive Replacement: passo 4, imagem 1 %32
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Optical Drive Replacement: passo 5, imagem 1 %32 Panasonic Toughbook CF-29 Optical Drive Replacement: passo 5, imagem 2 %32
    • Push the exposed switch to the left to eject the optical drive.
Conclusão
Clint Kirsop
Membro desde: 04/13/10
109 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 27-93, Amido Spring 2010 Membro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
Membros da 4
Autoria de 26 guias
Um comentário
What kind of USB enclosure would this fit in?
Terence Higgins - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 6,796
