Ir para o conteúdo principal
Introdução
The purpose of this guide is to show how to properly remove the optical drive.
  1. Locate the bay door for the battery on the left side of the laptop.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Slide the latch to the right and then down to unlock it. Pull out the battery.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Flip the device upside down with the handle facing away from you.
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Slide the latch cover to the right.
    • Slide the latch cover to the right.
  5. Push the exposed switch to the left to eject the optical drive. Push the exposed switch to the left to eject the optical drive.
    • Push the exposed switch to the left to eject the optical drive.
Conclusão
2 outras pessoas concluíram este guia.
Clint Kirsop
Membro desde: 13/04/2010
82 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 27-93, Amido Spring 2010 Membro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membros
24 Guias de autoria
Um comentário
What kind of USB enclosure would this fit in?
Terence Higgins - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 6,524
