Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the bay door for the battery on the left side of the laptop.
Slide the latch to the right and then down to unlock it.
Pull out the battery.
Locate the door for the hard drive on the right side of the laptop
Push and slide the latch up to open the hard drive door.
Pull out the hard drive.
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Push the exposed switch to the left to eject the optical drive.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Now the back cover should be off and you can access the inside of the casing.
Remove the black and white wires attached to the wireless card by simply pulling up.
Peel back the black cover to expose the clips holding in the wireless card.
Using a pair of plastic opening tools, push the two metal tabs away from the card.
The wireless card should now easily disengage from the motherboard.
Pull the card horizontally away from you to remove it from its housing.
Unplug 3 cables
Lift up on brown tab to release cable
Pull cable up and out
Remove 2 long screws indicated with red circles
Remove the remaining screws indicated in blue
On the back of the unit, unscrew the three screws surrounding the serial port.
Lift the motherboard as shown, pull towards you and then up.
Detach the white ribbon cable, the white cluster connector, and the ribbon cable right next to the cluster
8 outras pessoas executaram este guia.
4 comentários
what about spare parts? is it possible cange MOBO and CPU? in order to upgrade the thoughbook?
Où acheter la carte mère?
MERCI
Sur Google, recherchez "DL3UP1396AAA Panasonic CF-29 System Board" (à rechercher sans les guillemets), vous aurez quelques résultats (j'ai vu au moins 2 sites qui la propose à la vente), par contre, elle est cher.
Autre recherche possible : "DL3UP1396BAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Autre recherche possible : "DL3U11213FAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Brendan -
