Ir para o conteúdo principal
Panasonic Toughbook CF-29 Motherboard Replacement
O que você precisa
  1. Panasonic Toughbook CF-29 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Motherboard Replacement: passo 2, imagem 1 %32 Panasonic Toughbook CF-29 Motherboard Replacement: passo 2, imagem 2 %32
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Motherboard Replacement, Hard Drive: passo 3, imagem 1 %32
    • Locate the door for the hard drive on the right side of the laptop
  4. Panasonic Toughbook CF-29 Motherboard Replacement: passo 4, imagem 1 %32 Panasonic Toughbook CF-29 Motherboard Replacement: passo 4, imagem 2 %32
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
  5. Panasonic Toughbook CF-29 Motherboard Replacement, Optical Drive: passo 5, imagem 1 %32
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  6. Panasonic Toughbook CF-29 Motherboard Replacement: passo 6, imagem 1 %32
    • Slide the latch cover to the right.
  7. Panasonic Toughbook CF-29 Motherboard Replacement: passo 7, imagem 1 %32 Panasonic Toughbook CF-29 Motherboard Replacement: passo 7, imagem 2 %32
    • Push the exposed switch to the left to eject the optical drive.
  8. Panasonic Toughbook CF-29 Motherboard Replacement, Back Cover: passo 8, imagem 1 %32
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  9. Panasonic Toughbook CF-29 Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  10. Panasonic Toughbook CF-29 Motherboard Replacement: passo 10, imagem 1 %32
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  11. Panasonic Toughbook CF-29 Motherboard Replacement: passo 11, imagem 1 %32 Panasonic Toughbook CF-29 Motherboard Replacement: passo 11, imagem 2 %32
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  12. Panasonic Toughbook CF-29 Motherboard Replacement: passo 12, imagem 1 %32
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  13. Panasonic Toughbook CF-29 Motherboard Replacement: passo 13, imagem 1 %32
    • Now the back cover should be off and you can access the inside of the casing.
  14. Panasonic Toughbook CF-29 Motherboard Replacement, Wireless Card: passo 14, imagem 1 %32
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  15. Panasonic Toughbook CF-29 Motherboard Replacement: passo 15, imagem 1 %32
    • Peel back the black cover to expose the clips holding in the wireless card.
  16. Panasonic Toughbook CF-29 Motherboard Replacement: passo 16, imagem 1 %32
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  17. Panasonic Toughbook CF-29 Motherboard Replacement: passo 17, imagem 1 %32 Panasonic Toughbook CF-29 Motherboard Replacement: passo 17, imagem 2 %32
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
  18. Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: passo 18, imagem 1 %32 Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: passo 18, imagem 2 %32
    • Unplug 3 cables
    • Lift up on brown tab to release cable
    • Pull cable up and out
  19. Panasonic Toughbook CF-29 Motherboard Replacement: passo 19, imagem 1 %32 Panasonic Toughbook CF-29 Motherboard Replacement: passo 19, imagem 2 %32
    • Remove 2 long screws indicated with red circles
    • Remove the remaining screws indicated in blue
    I had two more screws to remove in addition to those shown with the blue circles. One in the lower right corner so that you can remove the 14-pin connector that has a metal guard barely wrapped around the edge of the motherboard, the other is on a rectangular copper pad (and has a black arrow by the screwhead) above one of the blue circles near the lower left corner of the large module below the expansion connector.
    Richard Ekblaw - Responder
  20. Panasonic Toughbook CF-29 Motherboard Replacement: passo 20, imagem 1 %32
    • On the back of the unit, unscrew the three screws surrounding the serial port.
  21. Panasonic Toughbook CF-29 Motherboard Replacement: passo 21, imagem 1 %32
    • Lift the motherboard as shown, pull towards you and then up.
    • Do not yet try to fully remove the motherboard or you may destroy the connections
    Between the power connector and the back USB port, there's a post through the motherboard just below the #1 Philips screw you removed previously. The motherboard needs to be lifted off that post to get it out.
  22. Panasonic Toughbook CF-29 Motherboard Replacement: passo 22, imagem 1 %32
    • Detach the white ribbon cable, the white cluster connector, and the ribbon cable right next to the cluster
    I also had a 2-pin black connector/cable going to the daughterboard that needed to be removed.
  23. Panasonic Toughbook CF-29 Motherboard Replacement: passo 23, imagem 1 %32 Panasonic Toughbook CF-29 Motherboard Replacement: passo 23, imagem 2 %32
    • Remove the board.
Conclusão
8 outras pessoas executaram este guia.
Dylan Bloom
Membro desde: 04/12/10
373 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 27-93, Amido Spring 2010 Membro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
Membros da 4
Autoria de 26 guias
4 comentários
what about spare parts? is it possible cange MOBO and CPU?  in order to upgrade the thoughbook?
Concetto Salierno - Responder
I think y'all missed a step.
Gemini - Responder
Où acheter la carte mère?
MERCI
Pascal Cohu - Responder
Sur Google, recherchez "DL3UP1396AAA Panasonic CF-29 System Board" (à rechercher sans les guillemets), vous aurez quelques résultats (j'ai vu au moins 2 sites qui la propose à la vente), par contre, elle est cher.
Autre recherche possible : "DL3UP1396BAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Autre recherche possible : "DL3U11213FAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Brendan -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 25,808
