Ir para o conteúdo principal
Panasonic Toughbook CF-29 Keyboard Replacement
O que você precisa
  1. Panasonic Toughbook CF-29 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Keyboard Replacement: passo 2, imagem 1 %32 Panasonic Toughbook CF-29 Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the four screws above the keyboard using a Phillips #0 screwdriver.
  4. Panasonic Toughbook CF-29 Keyboard Replacement: passo 4, imagem 1 %32
    • Pry up the black panel covering the top of the keyboard.
  5. Panasonic Toughbook CF-29 Keyboard Replacement: passo 5, imagem 1 %32
    • Remove the five silver screws shown.
  6. Panasonic Toughbook CF-29 Keyboard Replacement: passo 6, imagem 1 %32
    • Pull up keyboard and place it face down on the trackpad
    • Be careful not to put tension in the ribbon cables attached to the underside of the keyboard
  7. Panasonic Toughbook CF-29 Keyboard Replacement: passo 7, imagem 1 %32
    • Remove screws shown from cover plate
  8. Panasonic Toughbook CF-29 Keyboard Replacement: passo 8, imagem 1 %32 Panasonic Toughbook CF-29 Keyboard Replacement: passo 8, imagem 2 %32
    • Pull cover plate out of place revealing the ribbon cable connections to the motherboard
  9. Panasonic Toughbook CF-29 Keyboard Replacement: passo 9, imagem 1 %32 Panasonic Toughbook CF-29 Keyboard Replacement: passo 9, imagem 2 %32
    • Remove the ribbon cable farthest from you.
    • Push the white tab (as shown in the second photo) to release the ribbon cable.
  10. Panasonic Toughbook CF-29 Keyboard Replacement: passo 10, imagem 1 %32
    • Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
Conclusão
3 outras pessoas executaram este guia.
Dylan Bloom
Membro desde: 04/12/10
373 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 27-93, Amido Spring 2010 Membro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
Membros da 4
Autoria de 26 guias
Um comentário
When replacing the KB, don'f forget the double sided fiberglass tape. The regular CF-29 KB is a backbone of thin aluminum sheeting, Most likely when you "pop" off the KB, its likely to bend. When you install a bent KB, it bounces when you type. Bend it back and tape it down with new tape. With the CF-30, removing that KB is totally different. Its locked down by brackets, not taped. You need to slide it forward unlocking it before popping it off, otherwise your KB keys start breaking. Be soft and confident, because you bet one chance to do it correctly. Sponsored by Black Hawk Toughbooks.
Black Hawk - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 17,192
