Ir para o conteúdo principal
Introdução
This guide will show you how to safely remove the hard drive from your laptop.
  1. Locate the bay door for the battery on the left side of the laptop.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Slide the latch to the right and then down to unlock it. Pull out the battery.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Locate the door for the hard drive on the right side of the laptop
    • Locate the door for the hard drive on the right side of the laptop
  4. Push and slide the latch up to open the hard drive door. Pull out the hard drive.
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
Conclusão
2 outras pessoas concluíram este guia.
Clint Kirsop
Membro desde: 13/04/2010
73 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 27-93, Amido Spring 2010 Membro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membros
24 Guias de autoria
This guide is missing all the steps to remove the hard drive from the caddy. Here's a more complete guide: http://www.bobjohnson.com/how-to-replace...
Ed Lasher - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 12,924
