Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide provides the steps to remove the back cover. This process is necessary to access many of the components inside.
O que você precisa
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
3 outras pessoas executaram este guia.
