Ir para o conteúdo principal
Panasonic Toughbook CF-29 Back Cover Replacement
O que você precisa
  1. Panasonic Toughbook CF-29 Back Cover Replacement, Battery: passo 1, imagem 1 %32
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Back Cover Replacement: passo 2, imagem 1 %32 Panasonic Toughbook CF-29 Back Cover Replacement: passo 2, imagem 2 %32
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Back Cover Replacement, Optical Drive: passo 3, imagem 1 %32
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Back Cover Replacement: passo 4, imagem 1 %32
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Back Cover Replacement: passo 5, imagem 1 %32 Panasonic Toughbook CF-29 Back Cover Replacement: passo 5, imagem 2 %32
    • Push the exposed switch to the left to eject the optical drive.
  6. Panasonic Toughbook CF-29 Back Cover Replacement, Back Cover: passo 6, imagem 1 %32
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  7. Panasonic Toughbook CF-29 Back Cover Replacement: passo 7, imagem 1 %32
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  8. Panasonic Toughbook CF-29 Back Cover Replacement: passo 8, imagem 1 %32
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  9. Panasonic Toughbook CF-29 Back Cover Replacement: passo 9, imagem 1 %32 Panasonic Toughbook CF-29 Back Cover Replacement: passo 9, imagem 2 %32
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  10. Panasonic Toughbook CF-29 Back Cover Replacement: passo 10, imagem 1 %32
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  11. Panasonic Toughbook CF-29 Back Cover Replacement: passo 11, imagem 1 %32
    • Now the back cover should be off and you can access the inside of the casing.
Conclusão
3 outras pessoas executaram este guia.
Rohun Heesen
Membro desde: 04/13/10
426 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 27-93, Amido Spring 2010 Membro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
Membros da 4
Autoria de 26 guias
Um comentário
thanks for this crucial tuatorial >
Joe Gutierrez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 10,050
