Introdução
This repair guide will show you how to replace the tape player unit of your Panasonic SA-PM17 by tearing down the device to the point where you can take the unit out and put a new one in.
O que você precisa
With a Phillips #0 screwdriver, remove the eight 9.5mm screws attached to the left and right panels of the device.
2 comentários
The problem with my micro system pm17 is that the tape drive's head does not work. I noticed that it is a gear that has the function to trigger,The gearbox has probably moved out of its original position and is now not turning the read head.How do I return the gear to the original position so that it re-engages the bedhead?
Add a comment
