Ir para o conteúdo principal
Panasonic RQ-2102 Holding Handle Replacement
O que você precisa
  1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: passo 1, imagem 1 %32 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: passo 1, imagem 2 %32 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: passo 1, imagem 3 %32
    • Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body.
    • There are two more screws inside the battery compartment. Remove those as well.
    • Cautiously remove the back of the device body. Be sure not to damage the cord that connects the two sides.
    • All of the screws are the same size.
  2. Panasonic RQ-2102 Holding Handle Replacement: passo 2, imagem 1 %32 Panasonic RQ-2102 Holding Handle Replacement: passo 2, imagem 2 %32
    • Carefully remove the handle. Make sure the handle catches on each side are intact.
    • Replace the old handle with the new handle.
    • Remember, if the handle catches are broken, the device must be replaced.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 588
