Introdução
In this guide, you will learn how to replace the cassette holder spring on this device. This is a small strip of copper that causes the cassette door to spring open when the 'eject' button is pressed. If it becomes bent, broken, or pushed out of position, it will prevent your cassette door from opening or playing cassettes.
O que você precisa
Remove the three screws from the back of the device body.
Remove both screws from the battery compartment.
Remove the back of the device.
