Ir para o conteúdo principal
Panasonic RQ-2102 Cassette Holder Spring Replacement
O que você precisa
  1. Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: passo 1, imagem 1 %32 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: passo 1, imagem 2 %32 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: passo 1, imagem 3 %32
    • Remove the three screws from the back of the device body.
    • Remove both screws from the battery compartment.
    • Remove the back of the device.
    • All screws in the body of this device are the same size.
    • When pulling apart the device, both sides are connected by a cord that could be damaged if care is not taken.
  2. Panasonic RQ-2102 Cassette Holder Spring Replacement: passo 2, imagem 1 %32 Panasonic RQ-2102 Cassette Holder Spring Replacement: passo 2, imagem 2 %32 Panasonic RQ-2102 Cassette Holder Spring Replacement: passo 2, imagem 3 %32
    • Make sure the brass colored spring by the cassette door is in the correct position.
    • Remove the screw that holds the spring if broken.
    • Remove the spring from the device.
  3. Panasonic RQ-2102 Cassette Holder Spring Replacement: passo 3, imagem 1 %32 Panasonic RQ-2102 Cassette Holder Spring Replacement: passo 3, imagem 2 %32
    • Replace the old spring with the new spring, making sure that it is installed in the correct position.
    • Insert the screw back into position, ensuring that it holds the spring.
    • If the spring is loose, tighten the screw.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Duração total: 1,024
