Ir para o conteúdo principal
Panasonic RQ-2102 Band on Three Digit Counter Replacement
O que você precisa
  1. Panasonic RQ-2102 Band on Three Digit Counter Replacement, Band on Three Digit Counter: passo 1, imagem 1 %32 Panasonic RQ-2102 Band on Three Digit Counter Replacement, Band on Three Digit Counter: passo 1, imagem 2 %32 Panasonic RQ-2102 Band on Three Digit Counter Replacement, Band on Three Digit Counter: passo 1, imagem 3 %32
    • Remove the three screws from the back of the device body.
    • Remove both of the screws from the battery compartment.
    • Remove the back of the device.
    • Make sure not to pull apart the cords that hold the device together.
  2. Panasonic RQ-2102 Band on Three Digit Counter Replacement: passo 2, imagem 1 %32 Panasonic RQ-2102 Band on Three Digit Counter Replacement: passo 2, imagem 2 %32 Panasonic RQ-2102 Band on Three Digit Counter Replacement: passo 2, imagem 3 %32
    • Carefully remove the band from the gear spindle.
    • Dispose of the old, broken band.
  3. Panasonic RQ-2102 Band on Three Digit Counter Replacement: passo 3, imagem 1 %32 Panasonic RQ-2102 Band on Three Digit Counter Replacement: passo 3, imagem 2 %32 Panasonic RQ-2102 Band on Three Digit Counter Replacement: passo 3, imagem 3 %32
    • Insert the new band into the gear spindle.
    • Twist the black spindle to make sure the counter works.
    • If the counter does not work, ensure the band is not broken due to installation.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,186
