Introdução
In order to repair the problems that may arise while using the Panasonic PV-GS9 you must disassemble the camcorder entirely. This will allow you to have three large pieces of the camcorder from which all the repairs can be made.
Ferramentas
Peças
Nenhum componente especificado.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Rotate the camcorder so that the tape compartment is facing you.
Remove the single 4.5mm black screw above the hook for the hand strap.
Undoing the strap on one end may help.
Rotate the camcorder so that the lens is facing you.
Remove the single 4.5mm black screw from the front panel.
Uma outra pessoa concluiu este guia.
