Introdução
A guide to removing the lens assembly on the camcorder.
Ferramentas
Peças
Nenhum componente especificado.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
Using two tools may be useful, if difficult.
Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
Remove the panel from the camcorder.
Using #00 phillips screwdriver, remove two 4.5mm black screws holding lens in place.
