Ir para o conteúdo principal
Panasonic Lumix ZS50 Lens Assembly Replacement
O que você precisa
  1. Panasonic Lumix ZS50 Lens Assembly Replacement, Battery: passo 1, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 2, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 2, imagem 2 %32
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 3, imagem 1 %32
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 4, imagem 1 %32
    • The battery should now be released; you may now remove the battery from the camera body.
  5. Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: passo 5, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: passo 5, imagem 2 %32 Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: passo 5, imagem 3 %32
    • Orient the camera so the bottom is facing up and the battery door is on the right side.
    • Remove four black screws from the bottom of the camera.
    • Remove two black screws from the right side of the camera.
    • Remove one black screw from the left side of the camera.
  6. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 6, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 6, imagem 2 %32
    • Remove the casing from the camera by hand or using a plastic opening tool.
  7. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 7, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 7, imagem 2 %32
    • Use a spudger to lift up and tug off the green button board.
    • Be careful to not damage the attached ribbon cable.
  8. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 8, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 8, imagem 2 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 8, imagem 3 %32
    • Remove the screen using the plastic opening tool, prying from the top.
    • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
  9. Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: passo 9, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: passo 9, imagem 2 %32 Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: passo 9, imagem 3 %32
    • Remove the three screws from the center of the copper plate.
    • Remove the four screws from the outer edges of the copper plate.
    • Use a plastic or metal spudger to pry the copper plate out of place.
  10. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 10, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 10, imagem 2 %32
    • Remove the casing from the circuitboard by hand.
    • Remove the HDMI port casing by hand.
  11. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 11, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 11, imagem 2 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 11, imagem 3 %32
    • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
    • Disconnect the circuitboard by hand.
    • There will be one orange ribbon cable attached to the top that can now be removed.
  12. Panasonic Lumix ZS50 Lens Assembly Replacement: passo 12, imagem 1 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 12, imagem 2 %32 Panasonic Lumix ZS50 Lens Assembly Replacement: passo 12, imagem 3 %32
    • Remove the seven screws surrounding the lens assembly.
    • Move all ribbon cables out of your way while unscrewing.
    • Remove the three springs surrounding the lens.
    • Apply pressure on the front of the lens to push the lens out.
Conclusão
Bridget Lathrop
Membro desde: 02/01/17
149 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 8-5, Whitney Spring 2017 Membro de Baylor, Team 8-5, Whitney Spring 2017
BU-WHITNEY-S17S8G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 41
Duração total: 1,066
