Ir para o conteúdo principal
Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: passo 1, imagem 1 %32 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: passo 1, imagem 2 %32 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: passo 1, imagem 3 %32
    • Remove the side panels by unscrewing the Phillips head screws on both sides of the camera.
  2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 2, imagem 2 %32 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 2, imagem 3 %32
    • Remove the back panel by unscrewing the two Phillips head screws on the bottom of the camera towards the back.
    • Lift the back panel from the camera and set it aside.
  3. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 3, imagem 1 %32 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 3, imagem 2 %32 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 3, imagem 3 %32
    • Unscrew the Phillips head screw shown in the picture to remove the front panel.
    • Remove the front panel to expose the bracket at the bottom of the camera.
  4. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 4, imagem 2 %32 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pry the right side of the bracket up to allow you to grab the bracket with tweezers.
    • Grab the bracket with tweezers and slide it toward the battery door to remove it from the frame of the camera.
Conclusão
Trevor Meyers
Membro desde: 03/03/15
356 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 310
