Ir para o conteúdo principal
Panasonic Lumix DMC-ZS6 Top Assembly Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS6 Top Assembly Replacement, Top Assembly: passo 1, imagem 1 %32
    • Remove the battery and the SD card.
  2. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 2, imagem 2 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 2, imagem 3 %32
    • Remove the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Remove the two 1.0 mm screws on the left with a Phillips #000 screwdriver.
    • Remove the two 1.0 mm screws on the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 3, imagem 1 %32
    • Carefully separate the back of the camera from the main body.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 4, imagem 2 %32
    • Use the tip of a spudger to flip up the black tabs on the ribbon cables.
    • Pull the ribbon cables gently to unseat them.
  5. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 5, imagem 1 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 5, imagem 2 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 5, imagem 3 %32
    • Remove one 1.0 mm screw from the bottom with a Phillips #000 screwdriver.
  6. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 6, imagem 1 %32
    • Carefully separate the front of the camera from the main body.
  7. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 7, imagem 2 %32
    • Use the tip of the spudger to disengage the plastic tab.
    • Carefully lift the selector switch away from the motherboard.
  8. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 8, imagem 1 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 8, imagem 2 %32
    • Remove three 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the spudger to disengage the metal tab. Carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 9, imagem 1 %32
    • Insert the tip of the spudger into the center hole of the tripod mount. Apply force in the direction facing away from the button.
    • Carefully lift the tripod mount out of the camera body.
  10. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 10, imagem 1 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 10, imagem 2 %32
    • Use the spudger to flip up the brown tab on the motherboard. Carefully unseat the ribbon cable.
    • Insert the tip of the spudger into the hole on the daughterboard. Apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 11, imagem 1 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 11, imagem 2 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 11, imagem 3 %32
    • Use the spudger to flip up the two tabs on the motherboard. Carefully unseat the ribbon cables.
    • Use the Phillips #000 screwdriver to remove the three silver screws.
    • Carefully lift the lens assembly out of the camera.
  12. Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 12, imagem 1 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 12, imagem 2 %32 Panasonic Lumix DMC-ZS6 Top Assembly Replacement: passo 12, imagem 3 %32
    • Use the tip of the spudger to disengage the tab on the back of the camera.
    • Use the tip of the spudger to disengage the two tabs on the front of the camera.
    • Carefully lift the top assembly out of place.
Conclusão
Derrick Thompson
Membro desde: 01/30/18
1.035 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S2-G5, Johnson Spring 2018 Membro de Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 296
