Ir para o conteúdo principal
Panasonic Lumix DMC-ZS6 LCD Assembly Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement, LCD Assembly: passo 1, imagem 1 %32
    • Remove the battery and SD card.
  2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 2, imagem 2 %32 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 2, imagem 3 %32
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 3, imagem 1 %32
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 4, imagem 2 %32
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: passo 5, imagem 1 %32
    • Use the tip of the spudger to flip up the metal tabs.
    • Lift the LCD panel out of place carefully.
Conclusão
Derrick Thompson
Membro desde: 01/30/18
1.035 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S2-G5, Johnson Spring 2018 Membro de Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 222
