Ir para o conteúdo principal
Panasonic Lumix DMC-ZS40 LCD Screen Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS40 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Panasonic Lumix DMC-ZS40 LCD Screen Replacement, Battery: passo 1, imagem 2 %32
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 2, imagem 1 %32
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 3, imagem 1 %32 Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 3, imagem 2 %32
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32 Panasonic Lumix DMC-ZS40 LCD Screen Replacement, LCD Screen: passo 4, imagem 2 %32 Panasonic Lumix DMC-ZS40 LCD Screen Replacement, LCD Screen: passo 4, imagem 3 %32
    • Unscrew the five 3mm screws located around the sides of the camera using a PH000 bit or Phillips 000 Screwdriver.
  5. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 5, imagem 1 %32 Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 5, imagem 2 %32
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 6, imagem 1 %32
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 7, imagem 2 %32 Panasonic Lumix DMC-ZS40 LCD Screen Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Turn the LCD screen over to the side exposing the connection to the motherboard.
    • Remove the display data cable connecting the LCD screen to the motherboard. Using tweezers, pry up the black retaining flap then gently pull the display data cable free.
    • Be careful when handling any display data cables in the camera as they are prone to tearing.
    • To close for reassembly, slide the display data cable back into the ZIF connector and close the retaining flap.
Conclusão
Osayamen Orhue
Membro desde: 02/14/17
174 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 20-3, Remmell Spring 2017 Membro de USF Tampa, Team 20-3, Remmell Spring 2017
USFT-REMMELL-S17S20G3
Membros da 3
Autoria de 10 guias
2 comentários
The photo in step #7 is helpful but not sufficiently detailed to explain how the Panasonic ribbon connector works. Fortunately, Panasonic has a very detailed video about how these connectors work: https://www.youtube.com/watch?v=5-tBX1UN... (The helpful part of the video starts at 1:24)
It is recommended that you use a soft-tip instrument to flip the connector’s latching bar upward to release the ribbon cable. Then insert the ribbon cable from the replacement screen and carefully press the bar back down.
William Lee Roberts - Responder
Do you need a #0000 Phillips as stated in another video, or will a #000 Phillips work to remove the screws. Will a JIS #0000 or #000 work better being it is a Japan Product. Please advise, Thanks
Robert Myers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 2,015
