Introdução
If you ever drop your camera and the lens cracks, this guide will help you replace your current broken lens with a brand new one.
O que você precisa
Find the battery/memory card door on the bottom right of the camera.
Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
Unscrew the five 3mm screws located around the sides of the camera using a PH000 bit or Phillips 000 Screwdriver.
Ferramenta utilizada nesse passo:Tweezers$4.99
Turn the LCD screen over to the side exposing the connection to the motherboard.
Remove the display data cable connecting the LCD screen to the motherboard. Using tweezers, pry up the black retaining flap then gently pull the display data cable free.
Once the corresponding ribbon cables have been detached, the lens assembly can be lifted right up.
3 outras pessoas executaram este guia.
Um comentário
My Lumix is a bit older and so did not follow exactly. But this was helpful enough to allow me to work through the lens issue. In doing some reading, often the lens doesn't need replacing, just a good cleaning or even to reset it in the housing which worked for me. One thing I would say is refrain from taking the plastic clamps off. They are hard to get off and usually snap due to how brittle they get. Instead, leave in place and be careful with the cable.
