Introdução
If there’s unwanted dirt or grime on your lens that can’t be gently scrubbed off of the lens glass, or if the lens or sensor itself is malfunctioning, broken, or showing other malfunctions, it might be necessary to access the internal lens components within your Lumix. This guide will allow you to remove and replace the lens to your Lumix.
Before you remove the lens assembly, take a look at this Troubleshooting Guide to ensure that there is not a simpler solution to your issue. Before you begin, make sure to turn the camera off and remove the battery.
O que você precisa
Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
Unscrew the four 3mm screws holding the LCD screen hinge in place using a Phillips #000 screwdriver.
Remove the four 2mm Phillips #000 screws on the sides of the exposed internal metal plate within the camera.
