Ir para o conteúdo principal
Panasonic Lumix DMC-ZS35 Back Casing Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: passo 1, imagem 1 %32 Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: passo 1, imagem 2 %32 Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: passo 1, imagem 3 %32
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 Back Casing Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-ZS35 Back Casing Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 Back Casing Replacement: passo 3, imagem 1 %32
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
Conclusão
John Schug
Membro desde: 02/04/20
97 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 Membro de UW Stout, Team S1-G2, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 155
