Ir para o conteúdo principal
Panasonic Lumix DMC-ZS3 Lens Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: passo 1, imagem 1 %32 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: passo 1, imagem 2 %32 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Lens Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-ZS3 Lens Replacement: passo 2, imagem 2 %32
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Lens Replacement: passo 3, imagem 1 %32 Panasonic Lumix DMC-ZS3 Lens Replacement: passo 3, imagem 2 %32
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Lens Replacement: passo 4, imagem 1 %32
    • Remove the two LCD board ribbon cables out of their sockets.
  5. Panasonic Lumix DMC-ZS3 Lens Replacement, Lens: passo 5, imagem 1 %32
    • Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-ZS3 Lens Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-ZS3 Lens Replacement: passo 6, imagem 2 %32 Panasonic Lumix DMC-ZS3 Lens Replacement: passo 6, imagem 3 %32
    • Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
    • The LCD ribbon cables connect the back cover to the rest of the unit.
    • Use the spudger to disconnect the LCD ribbons.
  7. Panasonic Lumix DMC-ZS3 Lens Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-ZS3 Lens Replacement: passo 7, imagem 2 %32 Panasonic Lumix DMC-ZS3 Lens Replacement: passo 7, imagem 3 %32
    • Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
    • Excessive force may damage the camera. Be sure to lift the lens slowly and carefully to avoid damage to other parts.
    • Unlock lens mechanism located on the bottom of the device using your fingers.
Conclusão
Kellen Ericson
Membro desde: 04/17/13
18 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-60, Johann Spring 2013 Membro de Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 62
Duração total: 3,261
